Hi everybody,
I have some issue with ATA and FAX (CCM 3.3.2 , ATA load ata18x-v2-16-ms-030327b-2.zip)
When I send a fax from Fax 1 on ATA 1 to fax 2 on ATA 2 the first half part of the page is printed and the second half is not printed.
The quality is very bad
The issue is the same with a local and a remote fax
The ATA is connected to the network at 10 Mbps Half duplex
Do you have some idea ?
Thanks for your help
Irene
