12-14-2002 11:28 AM - edited 03-12-2019 09:58 PM
I am running CM3.2.2c. I have ATA adapters that have 2.14ms for the firmware and the ATAs are configured with dhcp. After the 2 lines on the ATAs are set up with the device names ATAXXXXXXXXXXXX, eventually an SEPXXXXXXXXXXXX device name will show up with a new auto-registered number for the same adapter and will bring the 1st configuration offline. Is there a resolution or documentation on this issue?
Thank you.
12-20-2002 08:03 AM
These links below may be of use to you if you haven't seen them already....
How to Configure Cisco CallManager to Recognize ATA 186 Using SCCP
Cisco ATA 186 FAQ and Common Issues
12-20-2002 12:25 PM
If I recall correctly CCM 3.2.2C ---- ATA186 runs with 2.15.
12-23-2002 09:31 PM
Sounds like CSCdx88821. Also I remember an issue with this in code prior to 2.15 so you may want to delete the devices and try again with the latest ATA code.
