ATA Auto-Registration
I am running CM3.2.2c. I have ATA adapters that have 2.14ms for the firmware and the ATAs are configured with dhcp. After the 2 lines on the ATAs are set up with the device names ATAXXXXXXXXXXXX, eventually an SEPXXXXXXXXXXXX device name will show up with a new auto-registered number for the same adapter and will bring the 1st configuration offline. Is there a resolution or documentation on this issue?
Thank you.
Re: ATA Auto-Registration
These links below may be of use to you if you haven't seen them already....
How to Configure Cisco CallManager to Recognize ATA 186 Using SCCP
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_configuration_example09186a00800a892f.shtml
Cisco ATA 186 FAQ and Common Issues
http://www.cisco.com/warp/public/788/voip/ata-faq.shtml
If I recall correctly CCM 3.2.2C ---- ATA186 runs with 2.15.
Sounds like CSCdx88821. Also I remember an issue with this in code prior to 2.15 so you may want to delete the devices and try again with the latest ATA code.
132
