ATA FAXING PROBLEMS THROUGH PRI GATEWAY
Has anyone got faxing to work with the ATA186 through a PRI gateway? It keeps failing on the 3rd or 4th page? I have upgraded it to ver 2.14 and the 3660 router is running 12.2.8T3. Faxing across LAN/WAN works fine with no problem. All pages send and receive without a problem no matter how many.
dial-peer voice 1000 voip
preference 1
destination-pattern 8323662[3-7]..
progress_ind setup enable 3
session target ipv4:10.48.248.32
dtmf-relay h245-alphanumeric
codec g711ulaw
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 1001 voip
preference 2
session target ipv4:10.48.248.31
codec g711ulaw
fax rate disable
no vad
1 REPLY
Re: ATA FAXING PROBLEMS THROUGH PRI GATEWAY
A couple things come to mind...
The ATA-186 only supports fax speeds up to 9600 baud. Also the ATA-186 only supports fax pass-through; fax relay is not supported, something to do with DSP limitations. In what mode do you have the ATA-186 running; SCCP, H323, MGCP? I've had the best luck with faxing by configuring the ATA in H323 mode.
You can check the ATA-186 FAQ for more info.
http://www.cisco.com/warp/customer/788/voip/ata-faq.shtml
Tim Medley, CCNDP, CCNP+Voice, CWNA
Sr. Network Architect
VoIP Group
iReadyWorld
258
