02-09-2006 03:55 AM - last edited on 03-25-2019 06:50 PM by ciscomoderator
hello
i have a question about ata 186, why it is limited to one call in G729, it is due to hardware or software ?
02-09-2006 06:12 AM
hi
hope this link helps..
http://www.cisco.com/warp/public/788/voip/ata-faq.shtml
ATA 186 does not support two ports using G.729a codec simultaneously. The G.729 codec can only run on one port at a time. When one port uses G.729, other port will use G.711. The following combinations are allowed on the ATA 186:
Two simultaneous G.723.1 codecs
Two simultaneous G.711 codecs
One G.723.1 and one G.711 codec
One G.729A and one G.711 codec (G.729A is available on first-come, first-served basis)
regds
03-03-2006 01:54 PM
Thanks a lot for the info
