ATA mobile phone
Actually I have a Nokia22 designed to be connect to PBX extension system. That device has two analog interfaces: trunk and extension. I have tested with succesful results the Nokia 22 connect to a PBX extension. Doing the following steps:
* User dial mobile extension.
* Receive a dial tone.
* Dial code that allow user on PBX telephone dial again.
* Mobile gets digits and establish the call.
These is the normal proceeding but, it do not work on a callamanger system.
The problem.
* User dial mobile extension (Mobile connected to ATA port).
* Can dial digits but mobile seem not to recognize digits.
How can I do that. Has someone been involved on that problem?
Sergi.
1 REPLY
Re: ATA mobile phone
The mobile does work with the PBX system. You could check out if it is compatible with the CCM and other issues. Following is the troubleshooting guide which might be useful:
Troubleshooting Guide for Cisco CallManager, Release 3.1(1)
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_1/trouble/
Hope this helps.
89
