ATA186 - 2 Extensions possible?
Running CCM 4.02, have ata186's. Can't seem to create a button template for ATA to allow 2 extensions. ATA's have two phone ports, but can they only be programmed with one extension?
Re: ATA186 - 2 Extensions possible?
Each ATA port registers with Callmanager as a separate phone, so you would need to assign an extension to each phone. The first port has the MAC address of the ATA. The MAC for the second port is derived by dropping the 2 left-most digits of the ATA MAC and adding 01 to the right. Take a look at the ATA admin guide for confirmation.
http://www.cisco.com/en/US/products/hw/gatecont/ps514/products_administration_guide_chapter09186a00800c4d1b.html
Hope this helps. If so, please rate the post.
Brandon
Apart from what Brandon said, if you let autoreg on on the server, both ports should register.
128
