ATA186 and DTMF
I´m using ATA-186 Boxes for a Gate-Application.
You can phone a internal phone and this phone can open the door.
Also you can open the door with a code.
The supplier for this systems said, it will be done by dtmf.
I tried the lastest version fo the ATA-software but none of the settings will work.
The settings were in audio mode: 0x00050005, 0x00150015 and 0x00250025
The solution is within the LAN, so we have no GW-configs to make.
Any ideas?
re. August
1 REPLY
Re: ATA186 and DTMF
I have something similar with alarm panels all on ATAs (all had their GW pointing to a central unit). Below are my key settings using the H323 firmware. It's been a while, so I don't recall all of the bits and what they did. One of them disabled dtmf relay and carried it as voice. Make sure you're using G711
AudioMode: 0x00020002
ConnectMode: 0x00008010
RxCodec: 2
TxCodec: 2
-Chris
126
