ATA186 problems with new 2.15 versions
I received some ATAs with a new software version, and I can see only 1 port. I've many other ATAs working fine with version 2.15b1: I tried to find on CCO this version to downgrade the new ATA but I couldn't find it on the web. My CM version is 3.1.3a.
Did you have similar problems?
Do you know if it's possible to upload version 2.15b1 from the older ATAs (so I can then downgrade the new ones)?
Roberto
1 REPLY
Re: ATA186 problems with new 2.15 versions
We have several hunderds of ATA and had some problems with them, but this can be solved. Yes, you can downgrade the image version of the ATA, it is fairly simple.
By cmd line or by Call Manager.
hope it helps
MP
98
