ATA186 will not invoke ringing on Analogue phone
This is the first time I have set up an ATA186 and I am using it with CM3.1(4a).
I have installed the Skinny software image on to it and added 2 devices as a 7960s in CM, and assigned DNs as stated in documentation. I can make calls from either line, but when I try to call a DN on the ATA186 it does not cause the analogue telephone to ring. However if the analogue phone goes off hook, the call is connected and 2-way audio is available. The only problem is it just wont ring!
Any ideas?
I am in the UK and so I am using a converter for the RJ11 ports on the back of the ATA. Does this mean I have to make a configuration change so that the ATA uses the correct wires for ring signalling?
Peter
1 REPLY
Re: ATA186 will not invoke ringing on Analogue phone
Peter,
The problem is the connector that you are using in the back of the ATA.
There are 2 types in use in the UK Master and secondary/slave. If you look at a normal telephone socket a Master can be identified by the fact it has a large capacitor on the circuit board, a secondary doesn't. It is the capacitor in the circuit that causes the ring (for the telephony purists I know this is a simple explanation!).
The connector you have plugged in is a secondary which is typically used for digital extensions or second sockets (hence the name) on the same line.
Try to get hold of a master connector and it should solve all your problems.
Paul
104
