ATA188 NCS to Nuera Orca
gerwin.boschloo
The ATA188 is connected using MGCP 1.0/NCS 1.0 to a Nuera Orca V5.2 gateway. The format of the RSIP is wrong, it should be:
RSIP aaln/1@[128.107.139.111] MGCP 1.0 NCS 1.0 but it is :
RSIP 1 @[128.107.139.111] MGCP 1.0 NCS 1.0
How do I change the configuration so that the "aaln/" part is added to the RSIP.
Gerwin
gerwin.boschloo
problem has been solved, the EPID0orSID0: field should be filled with "aaln/1"
