11-18-2002 09:40 AM - edited 03-12-2019 09:36 PM
1) Can ATA188 connect to the ADSL modem with a dynamic IP address?
2) Does it support "peer-to-peer" mode, so two ATA188 adaptors can directly communicate to each other WITHOUT a gatekeeper?
Thank you!
11-18-2002 10:57 AM
With respect to your question:
1) You asked about connecting to "an ADSL Modem" as opposed to an "ADSL router". Do you envision connecting the ethernet cable from the modem directly to the "10/100SW" switched port on the the ATA188 and then connecting the other port to a PC running Windows XP or other PPPoE software? At the minimum, I think you'll need an inexpensive router (e.g. Cisco 806, ethernet in - ethernet out) between the two devices.
2) With respect to communicating directly without a gatekeeper, I'm not sure how to make that work. There is a service available, however, using a Session Initiation Protocol (SIP) Server and SIP-thru-NAT technology that I'm finding works VERY well for voice communications over the Internet. If you'd like to email me off-line, I'll help with more information and show you how to save money in using it. If you'd care to call, you can experience the voice quality for yourself!
F C Wood
832.521.9408
11-19-2002 08:56 PM
The answer for both is -yes
