Attendant Console Across Clusters
Is it possible to use attendant console between two clusters? I am looking to have an attendant on Cluster A use AC for both Cluster A and Cluster B on a relief basis when the attendant at Cluster B is away.
Thanks...
1 REPLY
Bronze
Re: Attendant Console Across Clusters
Nope, the AC client and IP phone only talks to 1 Cluster at a time, so it wont work.
You might be able to add a hunt member that sends the call to the other AC. Then when all the lines are busy, it gets sent to the other cluster. I have not verified that this will work though.
97
