12-16-2003 01:31 PM - edited 03-13-2019 03:03 AM
I think I already know the answer to this. NO!!
You cannot use the soundcard on the PC to interface a headset with Attendant Console. This would be because there is no codec correct?
12-22-2003 01:13 PM
As you said PC soundcard cannot be interfaced with a headset for Attendant console.
12-22-2003 01:32 PM
Thanks for confirming that!!
04-29-2004 03:27 PM
You can if you go with an all software solution. I'm using Attendant with IP Communicator. Works like a charm.
