Attendant Console Help
I have AC set up and I keep getting a "initialization of call contol failed. retrying...." and "no lines available" can someone please tell me what I'm doing wrong.
Thank You
Re: Attendant Console Help
Providing you have setup the pilot point, and specified agent members, the only aspect remaining is that specifically make sure that you create the AC user as per the installation documentation.
Failing to do this correctly will result in the error you are getting.
For your information, create the ac user in CallManager administration as follows:
First Name - Attendant
Last Name - Console
User ID - ac
User Password - 12345
Enter a PIN number and telephone number, be sure to check the enable CTI application use check box. This will enable the Attendant console to interact with CallManager.
Before the attendant can use the attendant console, you need to ensure that attendant console phones and pilot points are associated with the ac user.
ok, i do have all this setup. i still get the same errors.
any other suggestion?
Have both the TCD and CTIManager services been activated ?
Have you updated the jtapi plugin on the Attendant console ?
the TCD and CTIManager are activated.
what is the proceedure for the jtapi plug in?
Incidentally, are you running the lastest TCD, this would have been updated if you downloaded the latest Attendant Console and installed it on all CCMs in the cluster.
Look at the TCD service properties, the path to the executable for the new TCD should be C:\program files\Cisco\CallManagerAttendant\bin\tcdsrv.exe.
Have you also created the Attendant Console user through the attendant console user configuration in CCM admin (not the ac user), this is the login the user uses to log in to the console.
We had a similar problem. Make sure call park tick box is ticked under ac user.
131
