Attendant Console Issues
I currently have CCM 3.3.5 SR2
Attendant Console Ver.1.2.(1ES14)The Attendant can login OK.Call Control comes up,Attendant can go online.Console screen looks Ok.She can see an incoming call,but cannot answer it."Connect fail" msg.appears.She also cannot go off-hook to dial from console,same msg.Console had been working Ok.Any suggestions?
1 ACCEPTED SOLUTION
Re: Attendant Console Issues
I did run into one intermittent problem that an uninstall/reinstall fixed. You might try that.
Brandon
If you go to Help -> About in Attendant Console does the client version match the server version?
Brandon
Yes,it does.That was one of the first things I checked.Odd thing is we had the same problem with another console in the network.It lasted for about 1 1/2 days but it cleared itself,never to return.Just went away.
Brandon
Problem solved.The speakerphone was not enabled on the device.
Thanks for your input.
135
