Attendant console problem
When i run the attendant console at the same time with microsoft outlook it doesn't wotk. what can be the problem between these application ?
1 REPLY
Silver
Re: Attendant console problem
I dont think it has something to do with MS Outlook, you should better check the Event Viewer and AC Client logs.
Karzazi
Rate all helpful posts
115
