Community Member
Attendant Console Problems
Hi:
When i try to run the Attendant Console, i recibe the follow message:
"Login Failed: Phone device was not found. Verify that the MAC address on the underside of the phone is the same as the MAC Address specified in the Settings dialog."
What can i do?
1 REPLY
Highlighted
Silver
Re: Attendant Console Problems
First check if the phone is associated to the "ac" user. Next check if you are entering the correct MAC address on the AC client configuration.
153
