You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our test area to get started.
Attendant Console Speed Dials
Does anyone know where the attendant console speed dials are stored ?
I want to back up the Speed Dials that the specific Attendant has generated so that I can move them. I can't seem to find whether they are stored locally or on the Call Manager.
Any input would be greatly appreciated...
  • Other Collaboration Voice and Video Subjects
Re: Attendant Console Speed Dials
In CM 3.2 and 3.3, I know the information is stored on CM. After you install the AC, you can login at a different desktop with the SAME username and password, and the configuration will follow.
I agree. I can actually see that by login in from different desktops as you suggest .
The reason for the question is that I did this and somehow the main attendant speed dials all went missing. I am trying to see if I can locate them or if I have to start completely from scratch. Has anyone else experienced this ??
Any info would be appreciated..
178
