atutoattendant problems
I have configured autoattendant in CME but is not working. When I try to call I obtain a failed call.
My telco is a sip provider ( sip protocol ), so I have configured a sip account in the router with the username is 964812530 and pass xxxxxx
so the public number is 964812530
these are the files I have in the flash:
Router#sh flash:
System flash directory:
File Length Name/status
1 25886372 c2600-jsx-mz.124-1
2 1022976 cme-b-acd-2.1.0.0.tar
3 33949 app-b-acd-aa-2.1.0.0.tcl
4 83291 en_bacd_disconnect.au
5 37952 en_bacd_invalidoption.au
6 123446 en_bacd_options_menu.au
7 75650 en_bacd_allagentsbusy.au
8 63055 en_bacd_enter_dest.au
9 496521 en_bacd_music_on_hold.au
10 42978 en_bacd_welcome.au
[27866844 bytes used, 5687584 available, 33554428 total]
32768K bytes of processor board System flash (Read/Write)
When I try to call 964812530 from the PSTN (the number from I'm trying the calls is 667433712 ) this is the
debug voice ccapi inout :
Router#debug voice ccapi inout
voip ccapi inout debugging is on
Router#
*Mar 27 20:54:10.988: //17/xxxxxxxxxxxx/CCAPI/cc_api_caps_ind:
Call Entry Is Not Found
*Mar 27 20:54:10.992: //-1/9F6EA05E801C/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=667433712
----- ccCallInfo IE subfields -----
cisco-ani=667433712
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=964812530
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=0
cisco-rdnsi=0
cisco-redirectreason=-1
*Mar 27 20:54:10.992: //-1/9F6EA05E801C/CCAPI/cc_api_call_setup_ind_common:
Interface=0x84E54E24, Call Info(
Calling Number=667433712(TON=Unknown, NPI=Unknown, Screening=Not Screened, Pr
esentation=Allowed),
Called Number=964812530(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subsriber Type Str=Unknown, FinalDestinationFlag=TR
UE,
Incoming Dial-peer=1001, Progress Indication=NULL(0), Calling IE Present=TRUE
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALS
E), Call Id=17
*Mar 27 20:54:10.996: //-1/9F6EA05E801C/CCAPI/ccCheckClipClir:
In: Calling Number=667433712(TON=Unknown, NPI=Unknown, Screening=Not Screened
, Presentation=Allowed)
Out: Calling Number=667433712(TON=Unknown, NPI=Unknown, Screening=Not Screene
d, Presentation=Allowed)
*Mar 27 20:54:10.996: //17/9F6EA05E801C/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=667433712(TON=Unknown, NPI=Unknown, Screening=Not Sc
reened, Presentation=Allowed),
Called Number=964812530(TON=Unknown, NPI=Unknown))
*Mar 27 20:54:11.000: //17/9F6EA05E801C/CCAPI/cc_process_call_setup_ind:
Event=0x85284678
*Mar 27 20:54:11.016: //17/9F6EA05E801C/CCAPI/ccCallSetContext:
Context=0x85BC79E4
*Mar 27 20:54:11.016: //17/9F6EA05E801C/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 17 with tag 1001 to app "_ManagedAppProcess_autoatt"
*Mar 27 20:54:11.024: //17/9F6EA05E801C/CCAPI/ccCallDisconnect:
Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect C
ause=0)
Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
*Mar 27 20:54:11.212: //17/9F6EA05E801C/CCAPI/cc_api_call_disconnect_done:
Disposition=0, Interface=0x84E54E24, Tag=0x0, Call Id=17,
Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
Call Disconnect Event Sent
The debug ccsip all is attached.
And the config is attached too.
and the .tcl script is attachef too
I hope we can find a solution.
thanks in advanced
Silver
Re: atutoattendant problems
Check out if the name of the unity port on the Unity box match the one you have defined on the CME.Check if CME is integerated to the unity box.Then reboot unity.
I'm not using unity, it's all in the cme 3.3
I want to use the autoattendant of CME.
What was the solution because I am having similar problems.
Cant get TCL to work \\
application
service queue flash:app-b-acd-2.1.0.0.tcl
param aa-hunt1 7999
param number-of-hunt-grps 1
param queue-ln 6
param queue-manager-debugs 1
service aa flash:app-b-acd-aa-2.1.0.0.tcl
paramspace english index 1
param drop-through-option 2
param handoff-string aa
paramspace english language en
param max-time-vm-retry 3
param aa-pilot 0200
paramspace english location flash:
param drop-through-prompt _dt_prompt.au
param second-greeting-time 30
param welcome-prompt _aa1_welcome.au
param call-retry-timer 10
param service-name queue
141
