audio one-way
Could you support me.
I have a cisco as5300 conect to Excel switch through ISDN, the IOS 12.2.2.XA5 and vcware version is 9.08 C549 technologie.
Try do one call only work audio one-way.
This is the sh run display:
Building configuration...
Current configuration:
version 12.1
no service pad
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
hostname GRT_LA
logging buffered 32768 debugging
no logging console
enable secret 5 $1$bXV5$BuJnSvt3OWBE6sO7Py3NR0
resource-pool disable
ip subnet-zero
no ip finger
mgcp package-capability trunk-package
mgcp default-package trunk-package
isdn switch-type primary-4ess
mta receive maximum-recipients 0
controller T1 0
framing esf
clock source line primary
linecode b8zs
pri-group timeslots 1-24
controller T1 1
framing esf
clock source line secondary 1
linecode b8zs
controller T1 2
clock source line secondary 2
controller T1 3
framing esf
clock source line secondary 3
linecode b8zs
cablelength short 133
voice-port 0:D
voice-port 1:D
input gain 3
output attenuation 3
voice-port 3:D
gw-accounting h323
gw-accounting syslog
gw-accounting voip
dial-peer voice 200 voip
destination-pattern 53T
session target ipv4:63.170.116.71
tech-prefix 7998011
dial-peer voice 400 voip
destination-pattern 7998T
session target ras
dial-peer voice 10 pots
destination-pattern 1111
direct-inward-dial
port 1:D
dial-peer voice 500 voip
destination-pattern 33T
tech-prefix 7998011
dial-peer voice 600 voip
destination-pattern 305T
translate-outgoing called 305
session target ras
dial-peer voice 999 voip
incoming called-number .
num-exp 876....... 79981876.......
translation-rule 305
Rule 0 ^305 79981305
gateway
interface Ethernet0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
interface Serial0
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
clockrate 2015232
interface Serial1
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
clockrate 2015232
interface Serial2
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
clockrate 2015232
interface Serial3
no ip address
no ip route-cache
no ip mroute-cache
shutdown
no fair-queue
clockrate 2015232
interface Serial0:23
no ip address
ip mroute-cache
isdn guard-timer 3000
isdn T203 10000
no cdp enable
interface Serial1:23
no ip address
ip mroute-cache
isdn incoming-voice modem
no cdp enable
interface Serial3:23
no ip address
ip mroute-cache
isdn disconnect-cause 1
no cdp enable
interface FastEthernet0
ip address 199.254.188.48 255.255.255.224
no ip route-cache
no ip mroute-cache
duplex full
speed auto
h323-gateway voip interface
h323-gateway voip id ITGK ipaddr 64.251.19.80 1719
h323-gateway voip h323-id GRTLA.WWW.GW1
ip default-gateway 199.254.188.33
ip classless
ip route 0.0.0.0 0.0.0.0 199.254.188.33
no ip http server
logging 64.251.19.74
logging 64.251.19.70
line con 0
transport input none
line aux 0
line vty 0 4
exec-timeout 0 0
password 7 10491B0D06181C
login
end
I appreciate your support.
Thanks.
1 REPLY
Re: audio one-way
You might want to check out the following link:
http://www.cisco.com/warp/customer/788/AVVID/fix_1way_voice.html
Also as a side note I'd recommend you do not leave the passwords in when
pasting your configs to a public forum.
88
