authentication failed by using IVR prompt
hi,
I tested the ivr by the default TCL script "clid_authen_collect" in POTS.
When I picked up the phone and press access code , I hear the voice prompt
and press 12345# as account , 12345# as pin. but always authentication failed.
Did anyone has any suggestion ?
best regards
fred.
the following is my configuration and debug voip aaa
aaa new-model
aaa authentication login default local
username 12345 password 12345
dial-peer voice 53 pots
application clid_authen_collect
destination-pattern 1...
port 0:0
gw-accounting syslog
gw-accounting aaa
attribute acct-session-id overloaded
attribute h323-remote-id resolved
acct-template callhistory-detail
AS5300#
6d23h: voip_start_ccapi_accounting(620):
6d23h: voip_start_accounting_internal:
6d23h: voip_start_accounting_internal(620):
6d23h: get_acct_params: suppressed=0
6d23h: get_acct_params(620): Use method "h323" set by global config.
6d23h: method:
6d23h: cdrtag:
6d23h: voip_start_accounting_internal: Getting new uid
6d23h: voip_alloc_aaa_uid
6d23h: voip_aaa_acct_get_retrieved_attrs
6d23h: voip_aaa_acct_get_nas_port_details:
6d23h: get_nas_port: avail=1 type=4 nas-port=CAS 0:0:3
6d23h: voip_aaa_lock_adb: uid(175) count=1
6d23h: voip_start_accounting_internal: UID=175
6d23h: voip_start_accounting_internal: Telephony Leg
6d23h: calling num :
6d23h: called num :
6d23h: account num :
6d23h: setup time : *23:58:24.594 UTC Fri Jan 7 2000
6d23h: gateway id : AS5300.
6d23h: connection id : 291226E2 C49511D3 870FED2B 98A59736
6d23h: call origin : answer
6d23h: call type : Telephony
6d23h: incoming conn id: 291226E2 C49511D3 870FED2B 98A59736
6d23h: voip_start_authentication:
6d23h: name:
6d23h: callid: -1
6d23h: service: ivr tcl authentication
6d23h: method:
6d23h: voip_alloc_aaa_uid: NULL callEntry
6d23h: voip_start_authentication: UID=176
6d23h: voip_aaa_get_method_index(0): ERROR: method "h323" not defined.
6d23h: voip_start_authentication: No authen list
6d23h: name: 12345
6d23h: callid: -1
6d23h: method:
6d23h: voip_start_authentication: UID=177
6d23h: voip_stop_ccapi_accounting:
6d23h: voip_stop_ccapi_accounting(620): UID=175
6d23h: voip_send_stop_h323_sess_id_vsa(620):
6d23h: receive byte : 24
6d23h: transmit byte : 60480
6d23h: receive pak : 6
6d23h: transmit pak : 252
6d23h: connect time : *23:58:24.604 UTC Fri Jan 7 2000
6d23h: disconnect time : *23:58:36.974 UTC Fri Jan 7 2000
6d23h: disconnect cause: 39
6d23h: voip_stop_ccapi_accounting: Telephony Leg
6d23h: voip_aaa_acct_get_dynamic_attrs: No active record
6d23h: voip_aaa_unlock_adb: uid(175) count=0
6d23h: voip_aaa_cleanup_adb: dealloc uid (175)
6d23h: syslog_ccapi_accounting:
6d23h: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 291226E2 C49511
D3 870FED2B 98A59736, SetupTime *23:58:24.588 UTC Fri Jan 7 2000, PeerAddress 1.
.., PeerSubAddress , DisconnectCause 39 , DisconnectText bearer capability not
authorized (57), ConnectTime *23:58:24.598 UTC Fri Jan 7 2000, DisconnectTime *2
3:58:36.968 UTC Fri Jan 7 2000, CallOrigin 2, ChargedUnits 0, InfoType 2, Transm
itPackets 252, TransmitBytes 60480, ReceivePackets 6, ReceiveBytes 24
AS5300#
  • Other Collaboration Voice and Video Subjects
1 REPLY
Silver
Re: authentication failed by using IVR prompt
In the debug messages, you can find the error occurs at the line "6d23h: voip_aaa_get_method_index(0): ERROR: method "h323" not defined ". The catch here is, there is some misconfigurations related to h323-aaa commands on the gateway.
Hope this command given below is not missing in the gateway configurations.Check it out.
gw-accounting voip
Configure this after configuring the command gw-accounting aaa . For more explaination, the document given might help you.
Configuration Examples
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide09186a0080087eb0.html#1029667
213
