Authorization Codes on SRST / Call Forwarding
we are using CUCM 6.1 and we have developed a billing system for CM to bill the calls based on authorization codes. but once the ip phones are on the SRST mode we are not able to get the authorization codes. Further more we are facing same issue when call forwarding as well. is there any way we can get the authorization codes on above mentioned scenarios(on srst and call forwarding? pls advice.
thx in advence
1 REPLY
Re: Authorization Codes on SRST / Call Forwarding
you may want to check the CME as SRST option. If you get CallManager Express in SRST mode, you maybe able to get Forced Authorization Codes working, but I don't know if it can be included in billing.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmesrst.html#wp1023679
You may need the latest version of CME
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/vcallcon/ps4625/data_sheet__c78-484777.html
CME 7 shows : Account codes and call-detail-record (CDR) field entry
CME also has Call Forwarding features.
hope this helps!
:JoeL
137
