auto Attendant and Unity Call handler
Hi everybody,
CCM 3.3.3 sr3
Unity 4.0.3
This is my issue :
I create a Hunt Group with 1 physical phone and the second entry is a Unity Call Handler
My issue is that I am not able to join the Unity Call Handler in the Hunt group - It's busy.
In the hunt group for the 2nd number :
- I tried an RP that forward to Unity ( the RP number is a Unity Call handler)
- I tried en dummy phone that forward to Unity ( the dummy phone number is a Unity call handler)
All the time using the hunt group the call handler is busy
When I call directly the Call handler it works
Can somebody helps me
Thanks for your help
Irene
I saw a previous mail called Auto Attendant
Re: auto Attendant and Unity Call handler
We had an issue similar to this. We got round it by using a translation from a DN used in the hunt group. The Hunt Group DN was the translation DN which translated to the unity Call handler.
Make sure if you use Partions and CSS's these are setup as this can cause issues.
D
Thanks for your answer
I am going to test it and give you a feed back.
Question
Is the Unity Call handler need to be a route Point or a dummy phone ?
Irene
When I do this type of thing I usually use a CTI route point. The behaviour seems a little more consistent.
Regards.
Bill.
The test with the translation pattern doesn't solve my issue.
I have opened a TAC Case
Irene
The Cisco Tac Guy just solve my issue
Activate (true) in the TDC service parameters the "Allow routing with the Unknown LineState"
Irene
124
