10-03-2006 10:38 AM - edited 03-13-2019 03:13 PM
I want to modify the aa.aef. can some one help me out.
I want a simple script with welcome prompt "welcome dial ext or 0 for operator."
10-03-2006 10:57 AM
Do you just want to edit the exsisting aa script? or Do you want to create a new one?
If you want to edit the prompt of the exsisting script you just need to record a new prompt. Otherwise you can follow the following links to get an idea.
hope it would be useful.
Are you using CUE, IPCC or just the AA embbeded script of the CCM??
Orlando M.
10-03-2006 11:06 AM
I am using CCM4.1 with extended services. if I create new script how i can upload?
10-03-2006 11:13 AM
I think you are just able to edit the welcome prompt, not the script.
you can record a new prompt, and then upload it. Then you can change the welcome prompt at the application configuration.
If you were using CUE, you can edit, or make a new AA script.
Orlando M
10-03-2006 05:34 PM
that about if i have cisco unity UM?
10-04-2006 05:52 AM
Maybe you can configure the CallHandler, to change the call flow.
Orlando.
