Auto attendant Script modification
I want to modify the aa.aef. can some one help me out.
I want a simple script with welcome prompt "welcome dial ext or 0 for operator."
Re: Auto attendant Script modification
Do you just want to edit the exsisting aa script? or Do you want to create a new one?
If you want to edit the prompt of the exsisting script you just need to record a new prompt. Otherwise you can follow the following links to get an idea.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5520/products_implementation_design_guide_chapter09186a00804993c2.html
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_programming_reference_guide_chapter09186a00800f0706.html
hope it would be useful.
Are you using CUE, IPCC or just the AA embbeded script of the CCM??
Orlando M.
I am using CCM4.1 with extended services. if I create new script how i can upload?
I think you are just able to edit the welcome prompt, not the script.
you can record a new prompt, and then upload it. Then you can change the welcome prompt at the application configuration.
If you were using CUE, you can edit, or make a new AA script.
Orlando M
that about if i have cisco unity UM?
Maybe you can configure the CallHandler, to change the call flow.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/products_tech_note09186a00801e6ef6.shtml
Orlando.
162
