Auto Attendants / Schedules
A typical auto attendant deployment scenario may
have a site's main listed number forwarded to an
Unity auto attendant with an appropriate schedule
to determine if the standard or closed greeting
will be played.
If the hours were 8:00AM to 5:00PM MTWTF, this is
a walk in the park exercise.
I have a situation where two new requirements may
be necessary and I need some guidance to understand
if a technical solution with Unity is available.
1) They would like the schedule to allow for a time
other than :00 or :30, i.e. 17:20PM to be part
of the schedule.
2) They would like the schedule to allow for two
distinct closed greetings, one for lunch, and
another for after hours / weekends.
--- Thanks ---
1 REPLY
Re: Auto Attendants / Schedules
The Unity web based Sa is hard coded for 30 minute intervals, however the Audio Text Manager is capable of letting you set schedules up for 15 minute intervals with the "/schedules" command line option. You can't get any more granular than that, however, since it's stored as a series of 15 minute flags. You can check out the audio text manager on its home page here:
http://www.ciscounitytools.com/APP_AudioTextManager4.htm
for the two distinct after hours greetings you'll have to use a similiar technique as for holiday greetings where calls are sent from the day greeting to a "lunch greeting' handler which passes the call on to the "night greeting" handler when it's not time for lunch - so three handlers assigned to 2 schedules. You can check out the Audio text Applications in Unity paper on the Documents page of www.CiscoUnityTools.com for more on the holiday schedule stuff...
93
