Bronze
Auto disappearing content using Refresh header?
We're pushing a CiscoIPPhoneExecute to a phone. The phone requests the page (CiscoIPPhoneText) in the execute request.
The requested page needs to allow the user to respond to a question. If the user doesn't answer to the question, the question should disappear.
Can we cause the page to disappear after a set amount of seconds? I've tried a Refresh with url 30; Init:Services, but this doesn't work.
Does anyone have an idear on how to make the page disappear after x seconds?
Erik
1 ACCEPTED SOLUTION
Re: Auto disappearing content using Refresh header?
Does the phone make the refresh request after 30 seconds? I haven't tried such high values.. I'm usually operating with 1 - 5 seconds, and that works just fine for me.
Bronze
Fixed it.
Header "Refresh" with value "30; url=Init:Services"
... does work as expected. I made am mistake I should better not disclose any further :)
Erik.
Well.. we're all entitled to screw up every now and then ;)
Erik,
Hi! I'm having the same issue but I'm sure I'm doing right. I mean, HTTP-REFRESH is working as expected with IP Communicator but not within the physical device: Cisco 7960G Firmware: 8.0(9.0).
The device responds with: "HOST NOT FOUND" and after more tries it finally stays with the prompt message: "HTTP ERROR[12]".
I'm also implementing a feature similar to yours: like a pop-up window.
Which device/firmware are you using?
Thanks in advance.
Thanks a lot for this forum...
There are always alternate ways of doing things...
Within the HTTP-Refresh header, I don't use the URI "Init:Services" anymore. Instead, I use a normal URL (http://) that points to a page withe the following code:
Now it works, thanks!
123
