AutoAttendant and g.729a
Can you communicate with the AA server using the g.729a codec. I am using multiple regions because of a wan link. I can connect using g.711 with no problems but when using g.729a the AA does not answer.
Re: AutoAttendant and g.729a
Chad,
You cannot use g729a to access AA unless you have go through a dsp transcoder.
Spike
thanks for the info.. i am going to use an hdv module for my psnt connectivity. Can I use the dsp's in that module for transcoding?
You cannot use the hdv for transcoding. The dsp's in this module can be used by calls generated by the router itself.
If you want hardware transcoding you will need the 6608 card for Cat6K or the AGM for Cat4K.
100
