Automated Test Calls with CM 4.1(3)?
We're running CallManager 4.1(3) in our lab. We're looking at a utility that automatically grabs CDR data and makes it accessible in an easy format. I'm looking for a tool or method that will place many (100?) test calls in our lab cluster so I can then run this utility to see how/what it presents for CDR info.
On a separate but related topic I'd be interested to see if anyone has a similar tool for testing, such as after upgrades, etc.
Thanks - Rob.
Re: Automated Test Calls with CM 4.1(3)?
Oh to have an automated testing app. Just started playing around with the Phone Services SDK and got some ideas forming on how I might do this via automated dial outs and by a remote control app for the phones.
With your initial Q about automating dial outs, you could do the testing you require by pushing an Execute object with the Dial:xxxx URI to your lab phones. Just tried it out here and with some work, you could do exactly what you want. Start with pushing a Dial URI and then after a determined period of time, push the Key:Soft2 URI to End the call.
I've found it easier to use PHP for this, but your ASP skills would probably be above mine.
HTH - Nathan
Don't know if this may be useful for you, but you can start a call from the gateway via CLI, use
csim start
Another useful tool is sipsak. From there, you can simulate calls directed to a gateway / CCM SIP trunk:
http://sipsak.org/
102
