Super Bronze
Avaya - Cisco CM Integration
I've configured calling between a CallManager cluster and an Avaya S8300 via H323 as outlined in the documentation on the Interop Portal on Cisco...
The one problem I've had is that there is an option for 'Direct IP-IP Audio Connections' in the Avaya system.
If enabled, calls should go from Cisco phone--2800ISR as MTP--Avaya Phone.
If disabled, calls go from Cisco Phone--2800ISR as MTP--AvayaS8300--AvayaPhone.
The problem is that when I enable this option (although the CCM traces show the correct address), a 'show call active brief' on the router shows the address of the S8300, not the intended endpoint as reflected in the CCM log.
Predictably this gives one way voice- my ISR acting as MTP is sending media to the wrong place.
Anyone have any ideas?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
1 REPLY
Bronze
315
