Community Member
avvid network integration with novell ipx qos question
I am proposing an ipt solution on a campus site that is currently running native ipx and whilst i understand that there will be no qos issues on the campus, there are some remote sites (low bandwidth) that could suffer.
Will ipx sap updates and other ipx traffic take prioirty on links even if voice has been priority queued and can ipx packets be fragmented?
Any suggestions or relative experience welcome
1 REPLY
Re: avvid network integration with novell ipx qos question
QOS on LAN and Wan will accomidate both protocols, novells saps are generally very small in size, on the lan side of things, I would suggest dividing the protocols in to different broadcast domains ( VLANS), as for the IP traffic, priortize all your traffic on the WAN egress points using LLQ which will let you classify your traffic.
107
