AXL call for dummies
I am trying to get the most simple of AXL calls to work on my ccm 6 server, it is so difficult to find good documentation. If someone could please answer me these questions
1. What address do I send the axl call too?
I have been using https://ccmserver:8443/axl/
I really wish to do it with out the https as the cert on my CCM is giving IIS a fit.
Do I need to specify port 8443? Or is that just for AXL SQL calls
2.What are the minimal amounts of headers I need to send to keep CCM6 happy? Mime type? Authentication? Do I need to send payload bytes?
Does someone have a sample app that works in CCM6? Preferably in jscript but whatever works.
Re: AXL call for dummies
On CCM 5, it is this URL, not sure about CCM 6. I don't think it has changed:
https://ccm_ip:8443/realtimeservice/services/RisPort
Are you manually calling SOAP? I just use Eclipse generated SOAP stub classes. It creates everything for you based on WSDL given to it.
I am trying to write the posts by hand, i am using Ip phone serviecs axlquery.asp as an example.
I haven't seen alot of info about CCM6 being used by people. For isntance i couldnt find the wsdl file for 6.0 even though i know some of the calls have changed. I did try to load the wsdl found in AXL_Schema_5.0 but eclipse said it was not a valid wsdl file. in wsdl2java.
Found the wsdl file on my ccm server as documented, problem now is getting it fed into eclipse. Are you using eclipse for C or for Java? the Axis2 wasdl2java plugin doesnt like the wsdl file because its using older unsuppported calls. Throwing a "Encoded use is not supported" error.. What version of Eclipse/axis are u using?
i have the same problem to you~
a~~~~
You need to download eclipse with the built in web tools in order to open the wsdl file.
http://www.wmusers.com/forum/showthread.php?t=13278
212
