Community Member
AXLSOAP problems with CUCM 6.1
I got this strange problem, when i try to insert a user with the AXL addUser method i get in response nothing and the user is not inserted either.
Here you can find the whole log trace.
Is there something wrong in what i'm sending to the cucm?
Time : 1 - 11:41:45
Procedure: addUser
Operation: user, lab
SOAP Call HEAD:
POST https://172.16.2.20:8443/axl/ HTTP/1.0
Host:172.16.2.20
Authorization: Basic Y2NtYWRtaW5pc3RyYXRvcjoxYk1uY2MxYUI=
Accept: text/*
Content-type: text/xml
SOAPAction: "CUCM:DB ver=6.1"
Content-length: 587
SOAP Call BODY:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"> <SOAP-ENV:Body> <axl:addUser xmlns:axl="http://www.cisco.com/AXL/1.0" xsi:schemaLocation="http://www.cisco.com/AXL/1.0 sequence="1"> <newUser><firstname>user</firstname><lastname>lab</lastname><userid>ulab</userid><password>password</password><pin>00000000</pin><telephoneNumber>0</telephoneNumber><department>O=NCCLAB</department></newUser></axl:addUser> </SOAP-ENV:Body> </SOAP-ENV:Envelope>
SOAP Call RETURN:
Community Member
Re: AXLSOAP problems with CUCM 6.1
I finally get it working, it was a communication problem due to a wrong cURL initialization
Community Member
did you try to use the following instead:
Host:172.16.2.20:8443 ?
Laurent
170
