AXLToolkit question or how I can extract IPPHONES info from CUCM6
I have downloaded AXLToolkit, now I run
C:\axlsqltoolkit>java -cp .\classes;.\lib\saaj-api.jar;.\lib\saaj-impl.jar;.\lib
\mail.jar;.\lib\activation.jar;.\lib\jaxm-api.jar;.\lib\jaxm-runtime.jar;.\lib\x
ercesImpl.jar;.\lib\xml-apis.jar AxlSqlToolkit -username=AppAdmin -password=AppA
dmin1 -host=10.10.10.10
and receive this answer:
select * from device
Sending message...
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Header/><SOAP-ENV:Body><executeSQLQuery sequence="1237319007171"><sql>
select * from device</sql></executeSQLQuery></SOAP-ENV:Body></SOAP-ENV:Envelope>
Mar 17, 2009 2:43:27 PM com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPC
onnection call
SEVERE: SAAJ0007: Bad endPoint type (endPoint instance of URL)
com.sun.xml.internal.messaging.saaj.SOAPExceptionImpl: Bad endPoint type https:/
/AppAdmin:AppAdmin1@10.10.10.10:8443/axl/
at com.sun.xml.internal.messaging.saaj.client.p2p.HttpSOAPConnection.cal
l(Unknown Source)
at AxlSqlToolkit.sendMessage(AxlSqlToolkit.java:138)
at AxlSqlToolkit.execute(AxlSqlToolkit.java:199)
at AxlSqlToolkit.main(AxlSqlToolkit.java:244)
l(Unknown Source)
What I do wrong and what should I to to receive needed info?
What other way I can go to extract needed information. It shouldn't be Bulk Web.
Re: AXLToolkit question or how I can extract IPPHONES info from
it might be related to your java version, I have had random issues in the past where it said bad endpoint...I had to change my source code to rectify...
can you please provide ur java version?
with bulk web, do you refer to BAT??
i think AXL Toolkit cannot Connect to the Cisco Callmanager because username or password is not correct Or may be cannot find the host.
214
