Background Static on Call Handler Greetings
On nearly all of my Call Handler greetings, background static can be heard when listening to them over the phone (Cisco IP Phone internally or any phone externally from PSTN), but I can not hear the static when I listen to the greetings via PC speakers. Are there any settings that can be adjusted to try to remove this static?<br><br>
1 REPLY
Anonymous
N/A
Re: Background Static on Call Handler Greetings
Turns out is was caused by recoding the wav files with a subpar microphone plugged into a PC. I recommend using the phone to record the Call Handler's, unless anybody has a better recomended method to get good quality recordings.
95
