Backing up CCM and UnITY on an ICS7750
I'm not familiar with any tape backup options for the ICS7750
I am aware of a tape backup for the MCS's, but not he ICS. Would
you mind sharing the part number you are referring to?
Regardless, I've found that the best backup strategy is to
just dump the MCS.STI file on to a customer fileshare, and
let them back it up as they normally do. Less hardware to
manage and in reality : Cisco's "DR" plan for a CallManager Publisher is to
reinstall : from the Spirian load, and then point it at the MCS.STI.
: Do you have other insights or thoughts?
1 REPLY
Re: Backing up CCM and UnITY on an ICS7750
Best disaster recovery plan I implemented was image the blades put them on a shelf and wait...Hot swaps aren't very good if you spend 2hrs down time reinstalling from a teac drive and the spirian cd's
The latest and greatest sti back util is pretty cool though
111
