Community Member
Barcode scanner for ip phone rollout
I am doing a rollout of 152 phones and was wondering if anyone has used a barcode scanner to scan the barcode right off of the box, and into word, xcel. Then this info can be put into the bat. I didn't know if you needed some special software or just the scanner by itself.
Community Member
Re: Barcode scanner for ip phone rollout
I've done just that a couple times and it works fine!
Used a bar code scanner with a keyboard wedge - that way Excel just thinks the information is being typed in - then imported via BAT.
It's useful to have labels with the DN/User's Name on it to stick on the boxes as they are scanned.
Justin
Community Member
Yes we are doing that for every installation.
You will need a barcode reader which connect in parallel with
the keyboard (PS/2 plug) and goes in Excel and capture the
MAC addresses directly in the BAT file. You don't need any
additional software.
Kind regards
Christian Chautems
Community Member
Check here...
http://www.opticonusa.com/handheld.htm
We use them w/ the BAT and have had great success. It's a major time-saver.
1707
