Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
BARS backup problem
My BARS in CCM can not Backup the DATA. It has hold the status on backup process.
I have found that the Event viewer of CCM is
Event Type: Error
Event Source: Cisco Database Layer Monitor
Event Category: None
Event ID: 3
Date: 10/9/2005
Time: 1:21:24 AM
User: N/A
Computer: SM-CNDI-VA01
Description:
Error: kErrorCDRFilesBackingUp - CDR flat files are backing up.
App ID: Cisco Database Layer Monitor
Cluster ID: SM-CNDI-VA01-Cluster
Node ID: 10.127.4.11
Explanation: CDR flat files are not being removed. On the primary CDR server, verify that the InsertCDR service is running and properly configured. On a server not the primary, verify that the location for collecting CDR files is accessible via the network.
Recommended Action: Set trace for InsertCDR service to detailed and look for errors in the trace. Check enterprise CDR parameters for accuracy..
The BARS version is 4.0.8
And The callmanager is 4.13sr1
THX
Bronze
Re: BARS backup problem
Have you tried the steps shown in the error?
The main reason for this error message is the cdr flat file in the CDR Folder is not inserting in the database. Open the CDR folder in the call manager you will be seeing lot of files.
Check whether insert cdr service is running. If it is running restart it.
Check whether the problem is solved after restarting the service. if not you need to restart the database layer monitor service also. doing this will affect the call processing . so do it in a maintanacne window.
you should not see many files under cdr folder.
All the best
krishna.
134
