BAT 4.4(2) and 7912 Call forward settings
I'm trying to set the Call Forward Busy and No Answer flags on all phones in a partition using the Update Lines tool, and the query results were coming up odd.
I have about 140 phones, and the query only found 20 or so phones. I tried using the partion and directory numbers to select the phones.
After looking at which phones when being selected by the query, it became clear that BAT was not finding the 7912 phones.
Any chance there is an update to BAT that will get this working?
1 REPLY
Bronze
Re: BAT 4.4(2) and 7912 Call forward settings
Guess you are hitting this bug CSCea31491. and I find it is fixed in 4.4(3).As you can find in the RNE, It also affects 7902 phones.
116
