BAT INSTALLATION ISSUE
HI ,
I am trying to install BAT in my ccm server. I am having only one server in my setup. it is connected to other servers in another region via ICT.
I am getting a error "BAT SHOULD BE INSTALLED ON A MACHINE WITH PUBLISHER DATABASE. ABORTING SETUP".
But the ccm iam installing is publisher.
What needs to be done to fix this issue.
Krishna
Re: BAT INSTALLATION ISSUE
Open the regedit, go to
"HKEY_LOCAL_MACHINE\SOFTWARE\
Cisco Systems, Inc.\DBL\DBConnection0"
make sure that you have the servername instead of the ip address and try again.
I have checked the registry entry. DBConnection0 has the server name.
Is the servername case sensitive?
Krishna
DBConnection0 entry has a server name other than the callmanger hostname.
hostname of call magner is pdc2cm
SERVERNAME ENTRY under dbconnection0
has PDCCCM
Once we changed this to PDC2CM. We are not able to view anything int he callmanger web page. IT was throwing the error.
We reverted back to the old setting. after that we are able to access the ccm webpage.
I checked the configuration. It has cluster id as PDCCCM-CLUSTER.
HOSTNAME AS PDC2CM.
how to proceed to solve this issue.
KRishna.
Blue
is the call manager service running?
is the database layer monitor service running?
yes the ccm service and database layer monitor service is running
KRISHNA.
107
