11-24-2005 10:17 PM - edited 03-13-2019 11:22 AM
I am trying to upload a BAT file in CCM 4.1.(3) , but getting the below error.
SEP0014a917a4db -2147219945 CDBLException Dump: [Duplicate value not allowed]
SEP0014a917a4f0 -2147219945 CDBLException Dump: [Duplicate value not allowed]
SEP0014a917a690 -2147219945 CDBLException Dump: [Duplicate value not allowed]
SEP0014a9818ad6 -2147219945 CDBLException Dump: [Duplicate value not allowed]
I have noticed that the users has been added but phones records are not added.
TIA
11-24-2005 11:30 PM
it seems like the device names are registered in the databse, check if you have a device SEP0014a9818ad6 alredy configured on your ccm ?
br runar
11-24-2005 11:50 PM
you should check if the extns haven't been used in the past and were deleted. You need to delete them from routeplan -> unassigned DN's
11-25-2005 03:10 PM
this is not the case..I am working on the new installation.
11-25-2005 03:13 PM
nope the devices are not registrered in database.. when I tried than the user get added & phone record doesn't. In my second attempt again the user can added but not the phone database..
11-25-2005 04:20 PM
Can you add that phone manually to see if it'll give you an error?
11-26-2005 06:53 PM
yeah I can add the phones manually without any issue.
11-29-2005 07:30 AM
I have come across this issue in the past, do a search on the MAC Address In my case the set was imported, however the DN on line one did not import and I had to add manually not sure what the fix is .Hope this helps
