Best practice for displaying calling party ID
tripbrown
Level 4
Level 4
I have several different office codes in a CM 4.0. I need to prepend the area code and first two digits to the actual 5 digit extension for outgoing caller ID. I am doing this by setting External Phone Number Mask on each line and telling my route group to use that value. Is this the best way to display caller ID in this situation?
thisisshanky
Level 11
Level 11
You can do this any way you want. You can check ext. ph number mask and set the mask on each phone. If you dont want to do this (too much work), you can set the prefix at the route pattern or route list level. route list level overrides route pattern level.
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
jlzfeeney
I believe you can mask with XXXX also as long as outgoing number matches your DNs.
