Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Big problem with adsl pppoe voice, LLQ and QoS
Hello.
It has been very hard to me to deploy a solution it seemed easy....
I'm using a 827-4v as spoke and a 1760 as a hub, IPSEC tunnels, voIP, both routers connect directly to the internet via an ADSL link as a pppoe CLIENT, the hub has fixed IP address, the spoke dynamic.
I have a working tunnel between them, I can send data even voice but when there is network congestion the voice packets suffers the most.
READ about QoS, concluded that LLQ and LFI are features to resolve my problem, but when I configure the routers the only thing I have achieved is packet priority but NOT BANDWIDTH RESERV.
I HAVE NO IDEA WHAT AM I DOING WRONG, hundreds of docs explain how to do it PLEASE read my configs:
HUB --- Cisco 1760
version 12.2
no service pad
service password-encryption
service internal
hostname cuu00
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxx
username cisco password 7 xxxxxxxxxxxx
memory-size iomem 15
voice-card 0
aaa new-model
aaa authorization network hw-client-groupname local
aaa session-id common
ip subnet-zero
no ip source-route
ip telnet source-interface FastEthernet0/0
ip cef
vpdn enable
vpdn-group pppoe
request-dialin
protocol pppoe
class-map match-all voip
match access-group 100
policy-map qos_map
class voip
set precedence 5
priority 128
class class-default
set precedence 0
voice call carrier capacity active
mta receive maximum-recipients 0
crypto isakmp policy 1
encr 3des
authentication pre-share
crypto isakmp key xxxxxxx address 0.0.0.0 0.0.0.0
crypto isakmp keepalive 40
crypto ipsec transform-set rtpset esp-3des esp-sha-hmac
crypto dynamic-map rtpmap 10
set transform-set rtpset
match address 115
crypto map rtptrans 10 ipsec-isakmp dynamic rtpmap
ip address 192.168.100.15 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
speed auto
no cdp enable
h323-gateway voip interface
h323-gateway voip bind srcaddr 192.168.100.15
interface ATM1/0
bandwidth 512
no ip address
no atm ilmi-keepalive
pvc 8/81
pppoe-client dial-pool-number 1
dsl operating-mode auto
interface Dialer1
mtu 1492
bandwidth 512
ip address xxxxxxxxxxxxxxxxx
ip nat outside
encapsulation ppp
dialer pool 1
service-policy output qos_map
no cdp enable
ppp chap hostname xxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxx
ppp pap sent-username xxxxxxxx password 7 xxxxxxxxxxxxxxxxx
ppp multilink
ppp multilink fragment-delay 48
ppp multilink interleave
crypto map rtptrans
ip nat inside source route-map nonat interface Dialer1 overload
ip nat inside source static tcp 192.168.100.187 80 INTERNET_FIXED_IP 80 extendable
ip nat inside source static tcp 192.168.100.187 53 INTERNET_FIXED_IP 53 extendable
ip nat inside source static tcp 192.168.100.187 7 INTERNET_FIXED_IP 7 extendable
ip nat inside source static tcp 192.168.100.187 21 INTERNET_FIXED_IP 21 extendable
ip nat inside source static tcp 192.168.100.187 110 INTERNET_FIXED_IP 110 extendable
ip nat inside source static tcp 192.168.100.187 25 INTERNET_FIXED_IP 25 extendable
ip nat inside source static tcp 192.168.100.187 23 INTERNET_FIXED_IP 4444 extendable
ip nat inside source static udp 192.168.100.187 53 INTERNET_FIXED_IP 53 extendable
ip nat inside source static udp 192.168.100.187 7 INTERNET_FIXED_IP 7 extendable
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip route 192.168.6.0 255.255.255.0 Dialer1
ip http server
ip pim bidir-enable
access-list 100 permit ip any any dscp cs5
access-list 115 permit ip 192.168.100.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 199 deny ip 192.168.100.0 0.0.0.255 192.168.6.0 0.0.0.255
access-list 199 permit ip 192.168.100.0 0.0.0.255 any
no cdp run
route-map nonat permit 10
match ip address 199
snmp-server community public RO
no snmp-server enable traps tty
radius-server retransmit 3
radius-server authorization permit missing Service-Type
call rsvp-sync
voice-port 0/0
voice-port 0/1
voice-port 0/2
voice-port 0/3
mgcp profile default
dial-peer cor custom
dial-peer voice 1 pots
destination-pattern 00
port 0/0
dial-peer voice 2 pots
preference 1
port 0/1
dial-peer voice 3 pots
preference 2
port 0/2
dial-peer voice 4 pots
preference 3
port 0/3
dial-peer voice 106 voip
destination-pattern 06
session target ipv4:192.168.6.101
codec g726r32
ip qos dscp cs5 media
ip qos dscp cs5 signaling
line con 0
line aux 0
modem Dialin
modem autoconfigure discovery
transport input all
speed 115200
flowcontrol hardware
line vty 0 4
end
SPOKE --- Cisco 827-4V
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname cuu01
logging queue-limit 100
no logging console
enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxxxxxx
ip subnet-zero
no ip domain lookup
ip dhcp excluded-address 192.168.6.101
ip dhcp pool CLIENT
import all
network 192.168.6.0 255.255.255.0
default-router 192.168.6.101
no voice hpi capture buffer
no voice hpi capture destination
encr 3des
crypto isakmp key xxxx address INTERNET_IP_OF_HUB
crypto map rtp 1 ipsec-isakmp
set peer INTERNET_IP_OF_HUB
match address 115
class-map match-all voice
match access-group 101
policy-map qos-map
class voice
priority 96
interface Ethernet0
ip address 192.168.6.101 255.255.255.0
ip nat inside
no cdp enable
h323-gateway voip bind srcaddr 192.168.6.101
hold-queue 100 out
interface ATM0
no ip address
atm vc-per-vp 128
pvc 8/35
interface Dialer1
bandwidth 128
ip address negotiated
ip mtu 1492
ip nat outside
service-policy output qos-map
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer remote-name redback
dialer-group 1
no cdp enable
ppp authentication pap chap callin
ppp chap hostname xxxxxxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxxxxxx
ppp pap sent-username xxxxxxxxxxx password 7 xxxxxxxxxxxxxxxxx
ppp multilink
ppp multilink fragment-delay 75
crypto map rtp
ip classless
ip route 192.168.100.0 255.255.255.0 Dialer1
ip http server
no ip http secure-server
access-list 101 permit ip any any precedence critical
access-list 115 permit ip 192.168.6.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 120 deny ip 192.168.6.0 0.0.0.255 192.168.100.0 0.0.0.255
access-list 120 permit ip 192.168.6.0 0.0.0.255 any
dialer-list 1 protocol ip permit
no cdp run
match ip address 120
call rsvp-sync
voice-port 1
voice-port 2
voice-port 3
voice-port 4
port 1
preference 1
port 2
preference 2
port 3
preference 3
port 4
dial-peer voice 600 voip
session target ipv4:192.168.100.15
codec g726r32
line con 0
login
stopbits 1
line vty 0 4
exec-timeout 120 0
login
length 0
scheduler max-task-time 5000
end
When I apply the service-policy in the 1760 a note
appears telling me that CBWFQ is only supported on MLPPP interfaces, READ a "TALK to the expert" and somebody said that MLPPP IS NOT supported with pppoe... is this true???
HOW CAN I reserve bandwidth for the voice to be encrypted ????
What is wrong with the config's above???
ANY HELP WILL BE VEEERRRYYY appreciated...
1 REPLY
Re: Big problem with adsl pppoe voice, LLQ and QoS
I read you configurations and have some considerations to you.
To guarantee bandwith end-to-end you need rsvp and all routers between path need have rsvp enable. WHat is not possible in your net.
To resolve you problem llq is the best solution.
I have some things about you configuration that can help you.
HUB --- Cisco 1760
change to
match ip dscp cs5
class-map match-all signaling
match ip dscp cs3
-Never transport signaling with voice, this comunication need 0.5kbps per voice conversation.
policy-map qos_map
class voip
set precedence 5
priority 128
class class-default
set precedence 0
change to:
policy-map qos_map
class voip
!set precedence 5 - no need this
priority 128
class signaling
bandwidth 10
!assuming that you use 2 voice calls
class class-default
random-detect
!set precedence 0 no need this, all traffic that no
!match with precedence classes go into this call per
!default
match address 115
qos pre-classify
!qos pre-classify you order router classify qos before send opver tunnel.
codec g726r32
change-to:
codec g726r32
!you need use this codec??g729 reduce bandwidth
!consumption
ip qos dscp cs3 signaling
!you mark signaling widht different dscp
In SPOKE --- Cisco 827-4V , you make same configurations change (same 1760), and you qos must improve.
Any question my mail is j.medeiros@agm-tele.com, i QoS Certified.
Best Regards
Joao Medeiros
407
