08-13-2002 04:48 PM - edited 03-12-2019 08:20 PM
What's the normal way to block call starting with 1010?Thanks
08-19-2002 04:04 AM
hi there.
normal way is : create a route pattern, and click on "block this pattern"
greetings, gerhard
08-19-2002 07:29 AM
also don't forget to assign the dial pattern to a partition and assign to the call search spaces you want to block from dialin this number. We used this to block peoples calling card numbers.
08-19-2002 10:43 AM
We have a bunch of route pattterns created with 9.@. We would like to create this by using route filter which can make all the pattern consistent .Have you done this way? Thanks
