block 1010
What's the normal way to block call starting with 1010?Thanks
Re: block 1010
hi there.
normal way is : create a route pattern, and click on "block this pattern"
greetings, gerhard
Re: block 1010
also don't forget to assign the dial pattern to a partition and assign to the call search spaces you want to block from dialin this number. We used this to block peoples calling card numbers.
Re: block 1010
We have a bunch of route pattterns created with 9.@. We would like to create this by using route filter which can make all the pattern consistent .Have you done this way? Thanks
334
