Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Block incoming calls
I am looking for a way to block incoming calls from certain numbers. We are using MGCP and Callmanager 4.1.3.
Thanks in advance for your help.
Pavel Bogomolnyi
Bronze
Re: Block incoming calls
Pavel:
For H.323 you can use number translation, for MGCP I do not believe blocking is possible without telco intervention. If the numbers are to be blocked for the entire cluster it is possible for the telco or leased line provider of PRI/T1s to screen and block in our area, but is comes at a cost. You may want to check with them to find out.
Tony Huynh provided this link in a previous post regarding a similar question -
http://www.cisco.com/en/US/customer/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml#con13
I have heard of someone using translation patterns for inbound calls that match certain criteria and provide a recording through voicemail, but have not been able to implement it successfully.
Hope that helps.
Tom
Tom,
Thanks very much.
Pavel Bogomolnyi
187
