Block some outgoing calls on CCME 4.0
I'm trying to block some outgoing called numbers with this config:
voice translation-rule 1
rule 1 reject /^080/
rule 2 reject /^0905/
rule 3 reject /^0906/
voice translation-profile call_block
translate called 1
dial-peer voice 3 pots
translation-profile outgoing call_block
call-block translation-profile incoming call-block
call-block disconnect-cause incoming call-reject
destination-pattern 0T
incoming called-number 977556640
direct-inward-dial
port 3/0
The result it's OK with the "test" command but the translation rule don't work when i made a call.
Any idea?
1 REPLY
Bronze
Re: Block some outgoing calls on CCME 4.0
140
