12-21-2005 12:48 PM - edited 03-13-2019 11:38 AM
How do you block unwanted inbound pstn callers like telemarketers Using CallManager 4.1 if you know their Caller IDs?
Solved! Go to Solution.
12-21-2005 12:55 PM
If you are using H.323 Gateways you can use blocking tranlsation rules as described in this doc:
If you have MGCP GWs then unfortunattely unless you put CRA or Unity where you could do that in front of CCM you cannot block the calls based on ANI.
Chris
12-21-2005 12:55 PM
Chris
12-21-2005 01:06 PM
Thank you Chris, I thought about that but I was hoping to do it with in CallManager so the gateways wouldn't be touched.
12-21-2005 02:16 PM
Have you considered implemeting malicious call feature? It won't actually block the call but it can identify and mark the call. You can then report the calling party and have your telco block incoming calls from them.
