Blocking CLID info Internally
Can the calling party display information (number only) be blocked when dialing from extension to extension on CCM 3.3.2?
Silver
Re: Blocking CLID info Internally
This feature is still not availabe on CCM 3.3.2. Only external numbers can be blocked and not the internal extension numbers as of now.
Is this feature under development for future release? If so, what is the expected version and deployment time frame? Thanks!
Bronze
Here is a work around. I built a translation pattern *67.XXXXX (I'm using 5 digit dialing). With the Calling Party TransforM Mask = ZZZZZ and the Discard Digeits = PreDot. Now if you dial the *67 and a 5 digit number your number is replaced with the ZZZZZ number. It works but the problem is that if you have mulitple users who want to block their number on internal calls and want to replace the number with their own specific (ZZZZZ) number you would have to build multiple *XX translation patterns. Kind of clumsy.
84
